2.4G WiFi/ Bluetooth Patch antenna 433/868/915MHz LoRa module supporting chip antenna.
Learn More
Chip antenna
GPRS window patch antenna-RG316 line-SMA-J straight head (gold plated), line length 600mm
GPS + BD antenna-1 meter RG174 line (64 braided copper clad aluminum) -SMA-JE
GPS + BD antenna 1.8m RG174 line (64 braided copper clad aluminum) -SMA-JE
GPRS small suction cup antenna-3 meters RG174 line-SMA-JE (298mm steel wire)
480MHz small suction cup antenna-3m RG174 cable-SMA-JE
480MHz waterproof suction cup integrated antenna-1.5m RG174 line-SMA-JW (The 4th generation)
470 ~ 486MHz waterproof sucker integrated antenna-3 meters RG174 line-SMA-JE (sheath)
