• Home
  • About Us
    Company Profile Corporate Culture Honorary Award
    Our Partners
  • Product
    IoT Module Antenna
    FRI-LAB
  • Solution
    GPS Solution LoRa Solution Wi-Fi Solution
    NB-IoT Solution
  • Document
  • News
    Shenzhen B&T Technology Co., Ltd ( Short for B&T, NEEQ: 430597 ), Founded in 2003, B&T embedded modules add Wi-Fi, Bluetooth, LoRaWAN, LoRa, GPS, NB-IoT, 2.4G or GPRS wireless IoT connectivity to any device. Provide customers with a full range of RF solution modules, antennas, wireless performance testing and solutions.
    Latest News Company News Industry News
  • Sample Buy
  • Contact Us
  • TYPE-R
Antenna
Chat Now! Chat Now!
  • IoT Module
  • Antenna
  • FRI-LAB
Frequency Range
All
433MHz470-486MHz868MHz915MHz900/1800MHz2.4G2.4G/5.8G3G4G5.8GGPSGPS+BD3.5~6.5GHz
External Antenna
All
Sucker AntennaRod Antenna小辣椒天线羊角天线Paddle AntennaBread AntennaGPS Antenna
Built-in Antenna
All
FPC AntennaPCB AntennaShrapnel AntennaCopper Tube AntennaSpring AntennaCeramic Antenna
Accessories
All
RF CableConnectorTerminalThimble
  • 433-453MHz built-in antenna (spring ¢ 0.8 × OD5.5 × N19.75 × L33.8)-A4
    The cost of the spring antenna is relatively low,small size, easy to install, good antenna standing wave ratio performance, and also has good anti-vibration and anti-aging capabilities. The wireless module can be used in conjunction with it to
    Learn More
  • 2.4G built-in antenna (shrapnel: 35.4 × 31.7 × 8.8) -black 1.13 wire-terminal, see wire length 250mm (original IPEX)
    The shrapnel antenna has good conductivity, and it has a long service life and a high shielding effect.
    Learn More
  • 2.4G built-in antenna (PCB 60 × 18 × 1)-black 1.13 wire-end stripping: 2-2-1, L = 40mm-A1
    PCB antennas are widely used in single-frequency module circuit boards such as Bluetooth modules, WIFI modules, and ZIGBEE modules.
    Learn More
  • 2.4G built-in antenna (PCB 40 × 7 × 1) -gray 1.13 wire-terminal-1
    PCB antennas are widely used in single-frequency module circuit boards such as Bluetooth modules, Wi-Fi modules, and Zigbbee modules.
    Learn More
  • 2.4 / 5.8G built-in antenna (FPC 29 × 18)-gray 1.13 wire-terminal, L = 48mm-A1
    The FPC antenna is suitable for smart hardware products with complex frequency bands. It has stronger performance, higher integration, and lower cost.
    Learn More
  • 2.4G built-in antenna (FPC 45.3 × 7.2)-gray 1.13 line-IPEX-1
    Learn More
  • RF Radio Frequency Cable Double MCX-J Elbow-1
    RF cable (RF jumper) RF cable assembly is a combination of RF coaxial connector and flexible cable or semi-rigid, semi-flexible cable, widely used in microwave equipment and
    Learn More
  • RF cable SMA-K 11.4mm tooth length
    Learn More
<< 1234 >>
  • About Us
    Company ProfileCorporate Culture Honorary Award Our Partners
  • Product
    IoT ModuleAntenna FRI-LAB
  • Solution
    GPS Solution LoRa Solution Wi-Fi Solution NB-IoT Solution
  • Document
    Document
  • News
    Latest NewsCompany NewsIndustry News
  • Sample Buy
    Sample Buy
Contact Us
+86-755-29162996 ; +86-15989589908(skype)
Address: Room408-410, Building C, Huafeng Intelligence Innovation Port, Gushu, Xixiang, Baoan District, Shenzhen,518126 ,China
Copyright © 2020 Ai-Thinker Co., Ltd. All Rights Reserved
Terms of Use | Privacy Policy
