• Home
  • About Us
    Company Profile Corporate Culture Honorary Award
    Our Partners
  • Product
    IoT Device and Platform PCBA OEM/ODM Manufacturer AiPi Open-source Hardware
    IoT Module Antenna
    FRI-LAB
  • Solution
    Wi-Fi Solution Radar Solution LoRa Solution
    Bluetooth Solution GPS Solution Offline Voice Solution
    NB-IoT Solution
  • Document
  • News
    Shenzhen B&T Technology Co., Ltd ( Short for B&T, NEEQ: 430597 ), Founded in 2003, B&T embedded modules add Wi-Fi, Bluetooth, LoRaWAN, LoRa, GPS, NB-IoT, 2.4G or GPRS wireless IoT connectivity to any device. Provide customers with a full range of RF solution modules, antennas, wireless performance testing and solutions.
    Latest News Company News Industry News
  • Sample Buy
  • Contact Us
  • TYPE-R
Antenna
Chat Now! Chat Now!
  • IoT Device and Platform
  • PCBA OEM/ODM Manufacturer
  • AiPi Open-source Hardware
  • IoT Module
  • Antenna
  • FRI-LAB
Frequency Range
All
433MHz470-486MHz868MHz915MHz900/1800MHz2.4G2.4G/5.8G3G4G5.8GGPSGPS+BD3.5~6.5GHz
External Antenna
All
Sucker AntennaRod AntennaPepper antennaAngular antennaPaddle AntennaBread AntennaGPS Antenna
Built-in Antenna
All
FPC AntennaPCB AntennaShrapnel AntennaCopper Tube AntennaSpring AntennaCeramic Antenna
Accessories
All
RF CableConnectorTerminalThimble
  • 433MHz bread antenna-0.5m RG174 line-SMA-JE
    Bread antenna is widely used for broadcasting wireless digital TV transmission. The product has good radiation direction, high power resistance, strong weather resistance, and can adapt to different natural environments.
    Learn More
  • 4G small suction cup antenna (with bottom cover) -3 meters RG174 line-SMA-JW A1
    The suction cup antenna can support all-weather work. The bottom of the antenna is equipped with a strong magnetic force, which is commonly used in the communication system on the car.
    Learn More
  • 2.4G external white knife-type integrated antenna
    The rod-shaped antenna has better conductivity, does not need to be debugged, is easy to replace, and has high antenna gain. It is suitable for larger terminal devices with no space limitation.
    Learn More
  • 2.4G external white flat shape integrated foldable antenna
    The flat antenna is usually designed with a PCB circuit inside, which covers a wider area and is generally used in products such as home routers.
    Learn More
  • 2.4G external white 5dBi integrated antenna
    Learn More
  • 868MHz external black rubber duck antenna
    Learn More
  • 4G external white paddle-shaped foldable antenna
    The paddle antenna uses a PCB circuit design,covers a wider area, generally used in home routers and other products.
    Learn More
  • 2.4-5.8G external black dual outlet antenna
    The rod-shaped antenna has better conductivity, doesn't need to be debugged,easy to replace, and has high antenna gain.Suitable for larger terminal devices with no space limitation.
    Learn More
<< 1234 >>
  • About Us
    Company ProfileCorporate Culture Honorary Award Our Partners
  • Product
    IoT Device and PlatformPCBA OEM/ODM ManufacturerAiPi Open-source HardwareIoT ModuleAntenna FRI-LAB
  • Solution
    Wi-Fi Solution Radar Solution LoRa Solution Bluetooth Solution GPS Solution Offline Voice Solution NB-IoT Solution
  • Document
    Document
  • News
    Latest NewsCompany NewsIndustry News
  • Sample Buy
    Sample Buy
Contact Us
+86-755-29162996 ; +86-15989589908(skype)
Address: Room408-410, Building C, Huafeng Intelligence Innovation Port, Gushu, Xixiang, Baoan District, Shenzhen,518126 ,China
Copyright © 2020 Ai-Thinker Co., Ltd. All Rights Reserved
Terms of Use | Privacy Policy
