NF-04-MI
RF chip BK2425
module size 18.0*12.0 unit:mm( ±0.2mm)
Modulation mode:GFSK modulation mode,Gaussian frequency shift keying
PackageSMD-8
Interface Adopt four-wire SPI interface, SPI port Maximum rate not greater than 10 M
Transmission power   Maximum is 4 dBm             Others refer to chip datasheet
RSSI support Not Support, simple packet loss count is supported only
Operating frequency: 2.4GHz ~ 2.525GHz,Adjustable,1MHz
Voltage range:1.9 ~ 3.6V,  typical value 3.3, Excessive voltage would damage the module
Data rate: support 2Mbps/1Mbps/250Kbps, more details refer to chip datasheet
Channel: 128 RF Channel, each channel is separated 1MHz
Test range 120m Sunny, no barrier , maximum transmit power
Receiving sensitivity: -96dBm@250Kbps, other details refer to chip datasheet
Antenna interface: on-board pcb antenna, 500 Characteristic impedance
Emission length: Single packet 1~32 byte, 3class FIFO
Received length: Single packet 1~32 byte ,  3class FIFO
Operating temperature: -20 ~ + 70℃ excessive temperature would damage the module
Storage temperature: -40 ~ +125℃ excessive temperature would damage the module
Standby current: 50µA ,other details are chip manual
Receive current: 16.5 mA (2Mbps), for other details see Chip Manual
Emission current:18 mA (4 dBm), for other details see the chip manual
