NF-01-S
RF chip Si24R1 Taiwan chip
Module size 28.6*15.3 unit:mm ±0.2mm
Modulation mode GFSK/FSK modulation mode Gaussian frequency shift keying
Package DIP-8
Interface Adopt four-wire SPI interface SPI port Maximum rate not
Greater than 10 M
Transmission power Maximum is 7 dBm Others refer to chip datasheet
RSSI support Support Signa lreceived strength detection
Operating frequency 2.4GHz ~ 2.525GHz Adjustable,1MHz
Voltage range 1.9 ~ 3.6V, typical value 3.3 Excessive voltage would damage the module10 Data rate support 2Mbps/1Mbps/250Kbps More details refer to chip datasheet
Channel 126 RF Channel Each channel is separated 1MHz
Test range 100m Sunny, no barrier , maximumtransmit power
Receiving sensitivity -94dBm@250Kbps other details refer to chip datasheet
Antenna interface On-board pcb antenna
Emission length Single packet 1~32 byte 3class FIFO
Received length Single packet 1~32 byte 3class FIFO
Operating temperature -20 ~ + 70℃ excessive temperature would damage the module
Storage temperature -40 ~ +125℃ excessive temperature would damage the module
Turn-off current 0.7µA other details in the chip manual
Standby current 15µA other details are chip manual
Receive current 15 mA (2Mbps) for other details see Chip Manual
Emission current 25 mA (7 dBm) for other details see the chip manual
