Rd-03E
Characteristic:
DIP package, standard 2.54mm pin
Radar support 24 GHZ ISM frequency band
Precise indoor and outdoor human movement, micro-motion sensing and distance, gesturerecognition detection
The radar antenna supports 1 receive and 1 transmit, antenna beam narrow, high resolution, frequency bandwidth, strong anti-interference
Provides visual tools to support configuration of detection distance intervals and settingsensitivity by range gate
The longest distance for sensing a moving human body is 6 m, and the longest distanceforsensing a slight human body is 3.5 m
High precision ranging:30 cm~350 cm±5 cm;350cm~600 cm±5% Accurate distance measurement, detection range of human body sensor module ±20°inazimuth, ±45°in elevation
Gesture recognition detection range: azimuth angle ±20°, elevation angle ±40° Ultra small module size:28*24mm
Automatically load the default configuration, plug and play
Support UART. Intelligent parameter adjustment of the radar can be realized throughtheserial port, which is convenient and fast
5V single power supply
Wall mount
Typical application scenarios:
Smart home appliances
Intelligent business
Smart Security
Smart lighting
