TB-05
Characteristics:
It can be directly controlled by the Tmall Genie without a gateway
1.1mm pitch SMD-20 package
6 PWM outputs
Onboard antenna, compatible with half-hole pad/through-hole pad
Brightness (duty cycle) adjustment range 5%-100%
Factory default cold color warm color duty cycle 50%
PWM output frequency 1KHz
With night light function
Color temperature switching function with wall switch
