BU04-Kit
Characteristic:
DIP-40 package
Complies with the IEEE 802.15.4-2015 UWB standard
Conforms to IEEE802.15.4z (BPRF mode)
Supports dual antenna channels
Channel 5 and channel 9 are supported
Easy integration without RF secondary design
Support for onboard antenna, compatible with IPEX external antenna
Integrated MAC function
The use of RTLS infrastructure extends the range of communication
Data rate supports 850 Kbps and 6.8 Mbps
Supports two-way ranging and TDOA and PDOA positioning schemes
Provides accurate positioning and data transfer
Positioning accuracy 10 cm
Supports high label density
Integrated HW AES 256
Supports the SPI interface
20 GPIO available
Integrated STM32F103 MCU
Programmable adjustment of the transmit power
Power supply can be external Type-C, and pin 3.3 or 5V power supply
