Characteristic:
Support FSK, GFSK, LoRa® modulation
Support frequency band: 803MHz~930MHz
Maximum transmit power is optional (see the design guide below for configurationmethod)
High sensitivity: as low as -137dBm@SF10 125KHz
Extremely small size 17*16*3.2(±0.2)MM, double row stamp hole patch package
Support spreading factors SF5/SF6/SF7/SF8/SF9/SF10/SF11
It has low power consumption in receiving state, and the minimum receiving current is 16mA
The module uses SPI interface, half-duplex communication, CRC, and up to 256 bytes of data packet engine
Support a variety of antenna installation methods, compatible with half-hole pad/through-hole pad/IPEX connector
